Home > General > Winter is Coming!!!!!!
Silverstone
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
ReggieMac wrote:
Is that the Nextzett one?
Yes - that's the one "There is no replacement for displacement" - W O Bentley
Post #705045 21st Nov 2024 1:36pm
Edwardthomas
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Fluid checks, little longer idle in the morning and windscreen protector is a god send (even with a heated windscreen.
On the topic on Winter - last week in the colder weather I found my car taking a little longer to start and showing the odd ' special programs off' message on start up. I have been told it's a sign of a low battery, measured it on the multi-meter and resting shows c. 11.9/12volts. I'd put a new 019 AGM battery on in the spring however did not re-programme it to the vehicle so a few questions...
- I have a new battery charger which I was going to try, 8A Ring smart charger, can the battery be charged whilst in the vehicle or do I have to remove it?
- Should I charge the vehicle up and reset the BMS, will this help keep charge?
TIA 2009 Pre-facelift TDV8 Vogue - Stornoway Grey, Ivory Leather, Clear Glass
Post #705474 26th Nov 2024 12:58pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
I have the new Ring 8A charger and it's set up through the towbar plug, 13 pin, "9" for live "13" for ground, works fine.
Just need to remember to not drive off with it connected.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #705483 26th Nov 2024 2:29pm
Edwardthomas
Thanks Andy, I have a towbar too so I need to shop around the connector to make it fit. From memory think it's a SAE connector 2009 Pre-facelift TDV8 Vogue - Stornoway Grey, Ivory Leather, Clear Glass
Post #705488 26th Nov 2024 4:30pm
AndyRoo
Hi,
This is what I have, seems ok, just need to make it watertight, no probs so far and the pins are screw capture, so no crimping or soldering to worry about, for a fiver, happy days.
https://www.ebay.co.uk/itm/386284828855
Post #705574 27th Nov 2024 7:18pm
