![]() | Home > Technical (L405) > Dpf regen tell-tale |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1654 ![]() ![]() ![]() |
I too have the MY2017 and yes this is indeed the information on pages 320-321 of the owners’ handbook.
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 218 ![]() ![]() ![]() |
I am also interested in this as I previously saw this on a Land Rover website and was not sure if this applied to all models or not?
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 85 ![]() ![]() |
I've been using some of the OBD2 readouts via CarScanner to monitor my regens and I've never seen any lights on the dash when it is doing an active regen.
@James,
@ReggieMac:
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 174 ![]() ![]() ![]() |
The green light must only be on models after 2017? I've never seen it on my 2015 and like Gremlin. I monitor every regen with the Kot Kit.
Can you actually get your 2015 to output the useful readings that the Kot thread suggests? Cos I can't! Or are you just using the exhaust temps like me? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1306 ![]() ![]() |
Certainly no green lite on MY18 2018 SE SDV8 4.4 Byron Blue |
Aaaaargh!
I can't get all the readings, regen status etc, but I use DPF soot concentration g/m3, exh temp sensor 2 bank 2, miles since last regen, sump oil temp and the DPF soot load %. They tell me everything I need to know and as others have stated, it becomes a bit of a mind game to calculate when the next regen is due. I set the speedo trip as soon as the regen is complete then when it approaches about 140 miles I start monitoring it ready for the next one. For some reason the profile for MY2015 wasn't much good and I find the Jaguar F Pace 3L diesel better. Happy Regens ![]() |
So I had to look ![]() 2018 handbook says--- ![]() Must be milli-secs as I have never seen it. I will have a regen tomorrow morning so will watch it carefully 2018 SE SDV8 4.4 Byron Blue |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Cheers guys.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 472 ![]() ![]() ![]() |
Just checked my handbook on 2020 4.4 and it says the same, but I’ve never seen it either, will be watching for it from now on. |
So this morning AR started as expected tried my best to scan dash when it finished, but sods law traffic was busy just at the time it finished, and never saw the magic green light!
