Home > Technical (L405) > L405 2017 propeller shaft rear 6 screws......
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hello everyone,
today I started removing the tank protection, it is rusted inside and out. The exhaust was easy to remove, the cardan shaft was causing problems, I loosened the 4 screws at the front, then the 2 screws of the center bearing, and also the 6 screws at the rear for the differential. At this point the cardan shaft doesn't want to come loose, it has enough room to come loose but doesn't move. Is there a trick? L 405, built in 2017, not with the large central nut at the back but 6 screws.
Thank you in advance!! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #704367 13th Nov 2024 1:49pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Hope it goes well and doesn't disintegrate when it is sandblasted.
Which paint will you use?
Looking forward to the next instalment.
Post #704400 14th Nov 2024 8:16am
