![]() | Home > Maintenance & Mods (L322) > De-cat Downpipe? |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
While i'm waiting for my EGR blanking kit to arrive, seen lots of Disco and Defender types have also put on a cat free downpipe because 'its not needed on diesels'
IIRC isn't some fuel injected into these to clean them out every now and again and this function would also need turning off? this might only be for the V6 and V8 units mind....
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I've de-catted several diesel engines and never had a problem when it came to MOT time. |
Although it is technically a good idea to remove the cat on a diesel and you will see an improvement in performance you may wish to wait awhile until the new requirements for mot's for 2012 are published.
good advice, thanks for that. __________________ 2015 FFRR SDV8 2011 FFRR TDV8 4.4 - Gone 2005 FFRR TDV6 - Gone |
IIRC isnt that only going to affect vehicles made after that date though as some vehicles back then still didn't have cat's on them?? (diesels of course) |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
I was warned about this recently as my Defender was fitted with the optional cat when it was ordered with one by the previous owner. I had it removed when I too needed a new front end of the exhaust system. It wasn't the MOT centre that warned me but the indie who does work on the vehicle 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
ogy Member Since: 24 Sep 2010 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
Ive done this with my td6 2 years ago. getting more mpg. Passed last 2 mots no problem. My cat was rattling when revs just above tickover so i removed it and cut it open. Removed the guts and welded it back together.[url] |
How much real mpg difference did it make?
The paper I read indicated that cars would be inspected to check for the cat being in place if the car was manufactured with one. There was no cut off point regarding back dating the requirement.
Is it just a change to indicate if one is still fitted, or if fitted and functioning?
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
if you cut round the seam then weld it back i doubt they would know as some after market cats do have big welds on them and the cat above wouldnt look out of place................but if the cats broken down you can just take it off and get a metal pole to poke down the hole and brake the cat up without the need to cut it open.......if you do it this way just wear a mask and protective clothing as the cat itself has some nasty stuff in it thats not at all good for your health "RANGEISM WILL NOT BE TOLERATED"
PS if you want some cash back dont forget to weigh in the bits of the cat as well in a nie strong bag, they are worth some cash you know these days.... |
when i used to break cars id sell them for between £30 - £60 a unit so a good bit of advice fromkingpleb
