Home > Maintenance & Mods (L322) > De-cat Downpipe?
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
De-cat Downpipe?
While i'm waiting for my EGR blanking kit to arrive, seen lots of Disco and Defender types have also put on a cat free downpipe because 'its not needed on diesels'
Anybody done this and got through a MOT?
Saw a straight through TD6 downpipe on ebay for £99 thinking it might be worth a shot if another comes up? __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #77559 25th Aug 2011 3:52pm
IIRC isn't some fuel injected into these to clean them out every now and again and this function would also need turning off? this might only be for the V6 and V8 units mind....
Would be nice as i want to gain some extra pull out of the engine without pushing parts too hard Smile
Post #77561 25th Aug 2011 4:22pm
I've de-catted several diesel engines and never had a problem when it came to MOT time.
Post #77580 25th Aug 2011 5:53pm
stu
the fuel burning thing is a Particule filter, these can be a pain in the rear too especially if you do alot of short stop start journeys it can ruin things and leave you with a bill for a new one. i don't think the FF has one of these though. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #77581 25th Aug 2011 5:54pm
Although it is technically a good idea to remove the cat on a diesel and you will see an improvement in performance you may wish to wait awhile until the new requirements for mot's for 2012 are published.
One item I remember seeing in the draft proposals was to check if the catalytic convertor was in place. If not and your car is listed as having one at manufacture I'm afraid it's a fail.
I presume this is to catch all the owners who remove them.
Post #77606 25th Aug 2011 6:32pm
DaveAngel
good advice, thanks for that. __________________
2015 FFRR SDV8
Post #77745 26th Aug 2011 7:32pm
IIRC isnt that only going to affect vehicles made after that date though as some vehicles back then still didn't have cat's on them?? (diesels of course)
Post #77777 27th Aug 2011 6:19am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I was warned about this recently as my Defender was fitted with the optional cat when it was ordered with one by the previous owner. I had it removed when I too needed a new front end of the exhaust system. It wasn't the MOT centre that warned me but the indie who does work on the vehicle 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #77782 27th Aug 2011 8:17am
ogy
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Ive done this with my td6 2 years ago. getting more mpg. Passed last 2 mots no problem. My cat was rattling when revs just above tickover so i removed it and cut it open. Removed the guts and welded it back together.[url]
[/url]
Post #77785 27th Aug 2011 8:41am
How much real mpg difference did it make?
Did it increase spool up for the turbo or low down toqrue at all??
Post #77786 27th Aug 2011 9:25am
The paper I read indicated that cars would be inspected to check for the cat being in place if the car was manufactured with one. There was no cut off point regarding back dating the requirement.
I think the number of mot failures may from 2012 be about to increase along with the sale of replacement cats. Smile
If the car wasn't origonally fitted with a cat at manufacture, no problem.
The idea of cutting the cat open, removing the insides and re-welding is probably the way to go, probably couldn't be checked on a diesel. Whistle
Post #77788 27th Aug 2011 10:11am
Is it just a change to indicate if one is still fitted, or if fitted and functioning?
If functioning how will this work as diesels IIRC are only tested for smoke, not emissions?
I can see the point about just cutting open and taking internals out but it would have to be done, neatly from the top for the MOT tester not to see it when checking the underside of the car and only have to be a small sized hole, one like the above would be easy to spot i guess??
Post #77790 27th Aug 2011 11:01am
pretlove
if you cut round the seam then weld it back i doubt they would know as some after market cats do have big welds on them and the cat above wouldnt look out of place................but if the cats broken down you can just take it off and get a metal pole to poke down the hole and brake the cat up without the need to cut it open.......if you do it this way just wear a mask and protective clothing as the cat itself has some nasty stuff in it thats not at all good for your health "RANGEISM WILL NOT BE TOLERATED"
Post #77791 27th Aug 2011 11:08am
PS if you want some cash back dont forget to weigh in the bits of the cat as well in a nie strong bag, they are worth some cash you know these days....
Post #77810 27th Aug 2011 2:40pm
pretlove
when i used to break cars id sell them for between £30 - £60 a unit so a good bit of advice fromkingpleb
mind you ive only ever sold them when they was in the metal still ive never sold them out of there unit so am not sure if they will sell "RANGEISM WILL NOT BE TOLERATED"
Post #77813 27th Aug 2011 2:51pm
