![]() | Home > Maintenance & Mods (L405) > parking sensors |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6768 ![]() ![]() ![]() |
I think you’ll struggle to replace them without removing the bumper(s) Got - 2017 SDV8 Autobiography in Loire Blue
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 511 ![]() ![]() ![]() |
i was thinking that but was hoping someone had a little tip/trick to remove them ..never mind |
getting this error code with gap tool B1B57-11 (2F) would this be a sensor or the wiring do you think ?
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
It could be faulty sensor or/and faulty wiring.
thanks kot yea ill try wd40 fingers crossed it sorts it if not then bumper off and see where that leads it |
tried wd40 no luck...how ever after replacing the park assist module and re-flashing it i now get a flashing orange light on the parking sensor button(didn't get anything before ) so some progress i did try going around to the sensors but couldn't hear anything from them |
ok parking sensor module replaced correct firmware confirmed (patrick gap tool )..i now have no error codes no error tone when starting the car and no flashing parking sensor button but still parking sensors don't work |
