Home > Maintenance & Mods (L405) > parking sensors
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
parking sensors
hi
its looking like i may have at least one parking sensor faulty (not sure if front or rear at the mo) and was wondering if it necessary to remove bumpers or can they be changed with out doing that ????
thanks will
Post #703845 5th Nov 2024 8:12pm
I think you’ll struggle to replace them without removing the bumper(s) Got - 2017 SDV8 Autobiography in Loire Blue
Post #703846 5th Nov 2024 8:43pm
will308f
i was thinking that but was hoping someone had a little tip/trick to remove them ..never mind
Post #703858 6th Nov 2024 6:36am
will308f
getting this error code with gap tool B1B57-11 (2F) would this be a sensor or the wiring do you think ?
thanks
Post #704256 11th Nov 2024 7:11pm
Kot
It could be faulty sensor or/and faulty wiring.
Its actually Front sensors power circuit - General electrical failure - circuit short to ground
Try first to give them a blast with WD40 it might displace any moisture etc 2018 SE SDV8 4.4 Byron Blue
Post #704283 11th Nov 2024 11:56pm
will308f
thanks kot yea ill try wd40 fingers crossed it sorts it if not then bumper off and see where that leads it Thumbs Up
Post #704287 12th Nov 2024 6:22am
will308f
tried wd40 no luck...how ever after replacing the park assist module and re-flashing it i now get a flashing orange light on the parking sensor button(didn't get anything before ) so some progress i did try going around to the sensors but couldn't hear anything from them
Post #704442 14th Nov 2024 3:33pm
