Home > Technical (L460) > HAND BRAKE
MJGH
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
HAND BRAKE
New L460 owner question.
On my L405 when stationary in traffic I pull up the little hand brake handle to apply and push the accelerator to release.
I assume the little square marked P by the gear lever in the L460 is the hand brake.
Pressed the button today when stopped in traffic and then pressed the accelerator to go.
Brake did not release. Tried pressing the button to release but no joy.
Assuming the hand brake will release automatically what am I doing wrong?
Apologies for what is probably a stupid question but there is no operators manual with the vehicle.
Post #703699 3rd Nov 2024 10:28pm
Renaco
Germany 2019 Range Rover Vogue SDV6 Corris Grey
L460‘s handbrake is integrated in the regular brake pedal and offers a double function. The parking brake and the hold function.
1.
Once stopped in traffic, press the pedal a bit more and you see the „hold“ sign on the dashboard.
The brake is now activated and as long as the engine is in drive, it releases automatically by pushing the gas pedal.
2.
Once the ignition is off, brake is automatically activated.
3.
There is on the menu also an „auto hold“ function, once activated it always works once stopped and holds the car automatically.
But, if you drive thru a carwash, you have to deactivate auto hold, as it doesn’t allow to roll in „N“ (neutral).
Also it is problematic once parking the car as it is connected to the pdc and it stops itself while there is still a lot of space left. So you need to push again the gas and then it’s getting risky as it moves than to fast.
I love the simple „hold“ function, as it works perfect, it’s a convenient upgrade. RR Classic 1998-2005
MINI 40th 1999-now
RRS SDV6 2011-2014
RRS SDV6 HYBRID 2014-2018
RRS P400e 2017-2018
RRS P525 2018-2022
RR VOGUE 2022-2024
RR P550e 2024
Post #703700 3rd Nov 2024 10:50pm
MJGH
Renaco thank you for the simple explanation.
Will save me sitting in traffic red faced with cars behind honking Very Happy Embarassed
Post #703702 3rd Nov 2024 11:00pm
Renaco
Rolling with laughter Thumbs Up RR Classic 1998-2005
MINI 40th 1999-now
RRS SDV6 2011-2014
RRS P400e 2017-2018
RRS P525 2018-2022
RR VOGUE 2022-2024
RR P550e 2024
Post #703726 4th Nov 2024 2:20pm
