Home > Maintenance & Mods (L322) > dash lights adaptive supension
miketrike
United Kingdom 2011 Range Rover SE TDV8 Baltic Blue
ok so i renewed rear shockers ..fitted new senders in top of front shockers to be sure wiring not cracked ,,i can go two days no dash lights then cant go two minutes and lights are on ..then after stopping motor for a few minutes restart car lights gone all works...been like this last few months ..dash says adaptive suspension fault hdc inactive suspension inactive etc....but yesterday it came up with extra fault ..parking brake fault but it works as it should and indeed after switching veh off for moment faults all gone...ive put gapiid on but all its says is fault on rear nearside abs ..i thought about buying new abs sensor and swapping out one wheel at a time..anyway any body any ideas where to go next....or anyone who knows how to fix ill come to you im about out of ideas on this ...car running great riding in style ..last question is there any multimeter test you can do on the front shock sensors that control adaptive suspension..just shows open circuit im not really sure how this sensor works..need someone local to dudley west mids ..but i dont mind ride out if not excessive distance ..apologies to moderator for misplaced posts .
Post #703566 1st Nov 2024 2:23pm
Baltic Blue
Don’t rule out the battery.
Low batteries cause all sort of random problems.
Post #703568 1st Nov 2024 2:49pm
miketrike
dash lights
Hello thanks for reply..looking thru your post is like reading about my own car history..my ffrr is baltic blue and my reg is rov 11 plate same interior etc..mine is now at 69k...yes i know all about batteries and range rovers ..my problem is only evident when car up and running ..im pretty sure its abroken wire /connection...ill keep looking ..shaking looms is not my favourite method of finding probs but not much else i can do ..was hoping someone may have inkling of direction to take ..stay safe ..
Post #703719 4th Nov 2024 11:47am
Baltic Blue
Mine’s on 91,000 and I have lost count of the number of times I have repaired the broken wires on the front, but never on the rears.
I made up a couple of new cables and they seem to be lasting better, at least 4 years I think.
Post #703724 4th Nov 2024 1:17pm
