Home > Technical (L322) > 2012 4.4tdv8 rear sensor - suspension fault |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
Broken sensor will cause the suspension to drop overnight as the self leveling system will be confused. Best to buy a genuine part as there have been reported issues with pattern parts. Before you order one check the physical linkage and the electrical connector / wiring. 2012 TDV8 Vogue (L322) |
29th Oct 2024 7:13am |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 161 |
If the ride height arm isn't broken, try running that wheel over a pothole to give it a thump.
29th Oct 2024 1:10pm |
RMac73 Member Since: 30 Jul 2022 Location: Inverness Posts: 17 |
Thanks Jaygee and dijit - I might try disconnecting it and giving it a clean but not holding my breath - although it worked for the other side last week....
29th Oct 2024 7:07pm |
Mine was intermittently faulty and I ignored it. It then failed and nearly left me stranded as the suspension collapsed. My advice is if itβs not the wiring or physical connector then replace it. I also now carry a spare front and rear sensor in the car to get me out of trouble. 2012 TDV8 Vogue (L322) |
29th Oct 2024 7:38pm |
