Home > Wheels & Tyres > Tyre Pressures on Cooper discoverer RT tyres
richardasbridge@aol.com
United Kingdom 2012 Range Rover Westminster 4.4 V8 Galway Green
Hello all,
I have a 2012 Westminster in Aintree Green that I absolutely love.
I have an issue with the ride quality and unfortunately it has the above tyre which I’m sure isn’t helping.
It is a 2 owner car which has been well looked after and has 100k on the clock.
What I would like to know is what tyre pressures do you guys think I should have the tyres inflated to?
Thanks in advance,
Richard.
Post #703090 25th Oct 2024 8:18pm
Gremlin500
@Richard, welcome to the forum!
Before posting, you are encouraged to use the “Search” function above.
As you can imagine, there is a plethora of information and probably several days’ reading on the subject of FFRR tyre choices in particular.
Depending on your wheel size, and on/off road preferences, there is much good advice.
On road, many prefer Pirelli all season either Verde or Zero tyres with the PNCS noise-cancelling system for 90% on road driving, but if you do much off-roading, there are other possibly better choices.
Perhaps you can have a good read, then ask about your final choices/options? Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #703091 25th Oct 2024 9:19pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I have those tyres - on the defender! Grabbers for me, but as Gremlin says, there are many opinions and it depends what you do with your car.
Post #704550 16th Nov 2024 9:33am
Vogue
Re: Tyre Pressures on Cooper discoverer RT tyres
richardasbridge@aol.com wrote:
Hello all,
Thanks in advance,
Richard.
I’ve been running AT tyres on RR’s for around 35 years - the 1st set were Goodrich Track Edge on a Classic. I have always run them at the std light load LR tyre pressure recommendations as AT’s tend to have stronger side walls / more ply’s which tends to give a slightly firmer ride and is compensated for by the light load pressure. Hope this helps. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #704617 17th Nov 2024 7:18am
