![]() | Home > Maintenance & Mods (L322) > Supercharged 4.2 reduced power |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
It sounds like the rubber air intake which feeds the air flow meter has collapsed between the inner wing and airbox. Check that first.
jammez Member Since: 28 Feb 2012 Location: Scotland Posts: 26 ![]() ![]() |
Thanks for the response, the air filter is new but I'll check out the intake hose in the wing and report back! |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
Could be the electric auxiliary coolant pump, had something similar happen on foot buried acceleration and it was the pump on its last legs, about 150 quid, iirc, make sure the wiring is correct, as some had the wrong orientation, ie pump rotating the wrong direction. Should be able to find which vin numbers were affected with a search on various sites inc here. 👍 |
Forgot to mention when it was happening I got the restricted performance message on the dash
I've already replaced the aux coolant pump in the the hope it might have been that but no difference (the wiring is correct). The annoying thing is I get no dash messages or no fault codes so I'm struggling to pin point it. I'll have a look at the wing intake this evening - I'm really hoping for something simple as it's already been an expensive year for it! |
Many thanks John. This was spot on, rubber boot had collapsed. I’ve removed and gone for a spirited drive and all seems good. New one on order. |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 184 ![]() ![]() |
Excellent news. 2012 Vogue TDV8 in Aintree green over sand |
Hi James,
