Home > Technical (L322) > Belt failure
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Belt failure
On my td6 the main belt broke and I was still able to ride until the temperature rose to the red zone (20klms) +-. Is there any chance that something has been damaged in the engine?
Post #702625 19th Oct 2024 8:18pm
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
It depends I guess.
The expansion tank cap incorporates a pressure relief valve and if it vented then the likelihood of damage occurring is higher as it indicated an significant increase in water temperature = increase in system pressure. Obviously with no water circulation the hot spots would be in the cylinder head area. Current: 2003 TD6 HSE. 161,000 miles
Previous 1993 Classic 3.9
Post #702659 20th Oct 2024 11:28am
