Home > My Range Rover > Another rescued L322 - 2011 5.0 SC Autobiography……Copart
Page 4 of 6 <123456>
Salter121
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Sumatra Black
I was genuinely on the fence about it and in reality I knew it was going to be a challenge - I went through the images in detail and the particular one of the engine bay. At first glance it looks complete; however, so many tell tell signs and red flags.....that said I still took the gamble. While Copart are not easy to deal with IMO if they list a car as starts, runs/drives etc that is part of the terms of the transaction and I would have been fully prepared not to accept the delivery.....that said be careful as Copart should have listed this car with mechanical issues and being partly stripped as the boot was fully of all the under trays etc.....none of this was mentioned and were even removed from he photo's! I regret not challenging this with Copart now; but we are where we are. The below image was from my initial "thats not right" list before I started bidding on it.......for me so long as it was running and driving I felt confident I could deal with it!
maxbasscat wrote:
Good stuff I remember looking at this car in the auction and felt it was too much for my skill set, the give away that someone had messed with the engine always puts me off. Well done you are very brave Thumbs Up
Post #702432 18th Oct 2024 7:50am
Salter121
The auction listing did not list anything wrong; but clearly it needed a lot of love…I have just been reading your amazing posts on your L322 5.0 SC project - puts my post to shame…. Some great reference points for me; thank you.
dhallworth wrote:
Nice project!
What did the advert say was wrong with it?
Today, I've just done over 200 miles in my 5.0 that was a project 12 months ago to. They really are fantastic cars when sorted properly.
Post #702547 19th Oct 2024 6:30am
dhallworth
Glad I could help Smile
Post #702805 21st Oct 2024 8:11pm
Gentle Giant
Scotland 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Can't wait to see how you get on...
All the best!
Post #703553 1st Nov 2024 12:31pm
Salter121
Update….
It’s been a while since I updated on the L322 5.0 SC…..after hitting issues I could not sort on the drive without a ramp I sent the car into Nick Kerner 4x4 to have the engine and gearbox dropped….with so many little things clearly re-installed incorrectly when they put the engine back in before it ended up at Copart, and the fact that it would not engage gears correctly and the gear box in Park was not holding it without the handbrake…..the only option was to drop the engine and start again……. At the end of October it headed off…………
Post #705875 1st Dec 2024 10:16pm
Salter121
So plan was for them to remove and replace engine assembly and carryout full inspection and gasket and seals check on engine and renew any missing or leaking parts……basically re-install engine to spec….and flag any major defects to be sorted……
Work carried out:
Front differential oil leak was due to a missing breather pipe - replaced
Damaged AIR CONDITIONING PIPE (condenser to Evaporator) - replaced
Damaged Fan Shroud + brush - replaced
Faulty OS SHAFT & CV JOINT ASSY - replaced
Front drive shaft not connected correctly + loose = reason for the issue with drive and P (park not working)
Re-route wiring harness correctly along with a million other things put back wrong…..all rectified
Full gearbox flush……incorrect oil used previously
Full fluids change……plugs etc…
Also installed new rear disks and pads……
Car still had electrical issues…which I would sort once I got the car back….the wiring harness has previously been badly worked on for some reason….. main goal for NK4x4 was achieved and that was getting car mechanically running………so the car came back…
Post #705879 1st Dec 2024 11:03pm
dhallworth
Glad to hear it's back and you can get on with the other bits and pieces now.
Look forward to more updates as work progresses.
Post #705880 1st Dec 2024 11:22pm
Dh25
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Great project! Will be watching your journey. All the best!
Post #705898 2nd Dec 2024 10:53am
Salter121
Electronics are the devils work
The issue appears to be an intermittent fault code causing the car to enter restrictive performance mode. Using a GAP tool, I identified the code as P0018-00 (AE) - Camshaft Position - Camshaft Position Correlation Bank 2 Sensor 1, which often points to a timing chain issue. The engine was running very rough, further suggesting this. However, after speaking with the original garage that sold the car, I learned the timing chains, covers, tensioners, and guides were all replaced at 113,000 miles in 2019, shortly before they sold it.
Given this, it seems unlikely that the car would have suffered timing chain failure again just 8 months later, unless the original job was poorly done or involved faulty parts. Upon inspecting the chain through the oil filler cap and testing with a screwdriver, I observed very little play in the chain, which further diminishes the likelihood of timing chain failure. Additionally, while the engine was running rough, it did not produce the characteristic "can of nails" rattle typically associated with timing chain or VANOS issues.
One concerning discovery was the extensive cutting and splicing of the wiring harness. Much of the wiring showed evidence of crude repairs, such as twisted wires held together with tape, without proper soldering or insulation. This raised questions about the vehicle's repair history.
Initially, I identified a fault in the wiring to the Variable Timing Solenoid on Bank 2, as well as issues with one of the Bank 2 Camshaft Position Sensors. My approach was to work backwards, unpicking and testing all previous repairs. I then reconnected everything properly, using soldered joints, proper connectors, and adequate insulation.
Fault codes were only present on Bank 2, so I decided to replace both Camshaft Position Sensors and both Variable Timing Solenoids on that bank. I also installed new wiring and connectors to ensure reliability. For the Variable Timing Solenoids, I opted for the newer plastic design (LR045390) instead of the older metal versions. This updated design was purchased directly from Land Rover, as I assume the redesign was made to address known issues.
This process was time-consuming but necessary to eliminate wiring and component issues as potential culprits. At this point, the engine is running better, but further monitoring will confirm whether the problem is fully resolved.
After all components were installed, and every single break in the wiring or prior repair was corrected properly, the engine is now running silky smooth, even up to temperature—no knocking, no rattling—just very smooth operation. The P0018-00 (AE) fault code is now gone, so clearly, these repairs resolved a key issue.
However, I now have two intermittent fault codes: P0345-02 (AF) - Camshaft Position Sensor A Circuit (Bank 2) - General Failure Information: General Signal Failure and P0390-02 (AF) - Camshaft Position Sensor B Circuit (Bank 2) - General Failure Information: General Signal Failure. Despite this, the GAP tool is showing signals from these sensors in the live data, which is confusing.
At this stage, it’s unclear where the issue lies - the sensors are all new - the wiring is good, so it must be some other aspect of the system or it is the timing chain....but can't see it. Further investigation is needed to determine the root cause of these intermittent fault codes.
I can clear the code and it remains gone for a while..... then and only on restart it pops up..... I am stumped!
Post #706005 3rd Dec 2024 1:44pm
Salter121
Work carried out:
Initial inspection video..... lots done I forgot to mention above.......
https://www.youtube.com/shorts/APTgzMyzVkI
Post #706007 3rd Dec 2024 1:57pm
Salter121
While tackling the previously mentioned electrical work, I also spent time preparing the car for its MOT. One major task was addressing the glass, starting with the front windscreen. I ordered a brand-new windscreen directly from Land Rover (LR039064), which is the standard glass with a rain sensor mount.
Although I considered upgrading to the climate glass, I ultimately couldn’t justify the additional cost. To ensure the installation was done perfectly, I was referred to a fantastic specialist with over 20 years of experience fitting glass into Range Rovers. He did an excellent job helping me get it fitted.
If you’re in a similar situation and need someone reliable for Range Rover glass work, feel free to PM me, and I’ll gladly share his contact details.
And a brand new Genuine Panel Cowl Top LR022996..... and brand new genuine A Pillars DCB500172 DCB500162
Post #706011 3rd Dec 2024 2:14pm
Salter121
Salter121 wrote:
The car had clearly been sitting for years, and the windows and paintwork suffered badly from contamination—almost as if the entire vehicle had been covered in clear coat overspray. I used my orbital polisher with various compounds to try and restore it, but the glass panels proved especially difficult.
I reached out to a few local glass polishers to get quotes for bringing the glass back to its original condition. Once I had a sense of the costs, I had to weigh up whether to repair or replace the glass. The front windscreen was particularly bad, scratched from someone using the wipers without blades, leaving it beyond repair. This led me to look for a replacement.
While considering my options, I realised that although polishing would cost around £400 plus VAT—considerably cheaper than replacing the glass with new panels—it still wouldn’t guarantee perfection. I wanted the windows to be flawless, so I started exploring the possibility of replacing each glass panel. During my research, I discovered just how many different glass options the L322 has. Having replaced doors and glass on my 4.4 TDV8 L322 before, I had always assumed all the glass was the same. But no....more to follow on this !
After spending countless hours polishing the side glass—and even consulting a professional glass polisher for a quote—I had to weigh the value of my time against simply biting the bullet and replacing the glass. I know it sounds a bit crazy, especially given the cost, but it was the only practical solution in the end.
With the old glass removed, I now have the option to either continue polishing it when I have spare time or sell it on eBay as a project for someone else to clean up.
I took advantage of the Black Friday sales and bought all Land Rover Genuine Glass directly from Land Rover, including LR017465, LR017466, LR017463, LR039062, LR039060, LR040920, and LR040918. All the glass matches perfectly, featuring a rear dark tint, laminated construction, and climate glass. As this is a car I will never sell.......it is a worthwhile investment.......
Post #706013 3rd Dec 2024 2:30pm
Salter121
When I first got the car, I knew the interior was going to need a lot of work to get it looking even remotely acceptable. Honestly, why anyone thinks it’s a good idea to put engine parts on leather seats is beyond me!
I’ve since spent a huge amount of time restoring the interior, and while it’s not mint, it’s a massive improvement from where it started. There’s still some work to do, but it’s incredibly satisfying to see how far it’s come already.
Post #706017 3rd Dec 2024 2:57pm
Salter121
Although I’m still dealing with the intermittent P0345-02 and P0390-02 fault codes that occasionally throw the car into restrictive mode, they held off just long enough for it to pass its MOT.
The last time this car had an MOT was back in 2019 at 116,742 miles—a mere 4,775 miles ago. It’s a small victory, but it feels great to have it roadworthy again after all this time! (and money)
Post #706019 3rd Dec 2024 3:03pm
dhallworth
That's a massive amount of work you've put into that car! A fantastic result with the MOT too! Well deserved after all of that effort!
Some excellent diagnostic work on the timing codes too.
Really hope it's plain sailing from here on for you. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #706057 3rd Dec 2024 10:17pm
