Home > Maintenance & Mods (L405) > Front seat modules
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Front seat modules
I have a suspected broken front drivers seat control module.
I have no rake adjust or front seat squab height adjust. Swapping the switch panel with passenger makes no odds.
Swapping the control module with passenger sides means all drivers side switches work but only for a 5mm or so movement for each press of any of the seat switches. Which is better than not moving it at all Which is what I did have.
So why does it only move 5mm with each press, does the module need plugging in and configuring? It works fine when i swap it back to passenger seat.
When the suspected broke drivers seat module is plugged into the passenger seat, nothing works! That bit i dont fully understand!
I have an autel which won't connect on diagnostics to the seat module.
Any suggestions? Currently thinking new seat module just don't know if I need to program it! Cheers
James
Post #702035 11th Oct 2024 8:59pm
M3bobby
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
5 second use per press is typical of a ECU that isn’t recognised on the CANBUS. That makes sense as I’d imagine the modules have different software versions, even if they are the same hardware number.
Post #702261 15th Oct 2024 10:45pm
JST
That's great to know, thank you for replying. Will get a new module on the way as also means its giving function although limited so motors/actuators all work. Just possibly then need to code new module. Cheers
James
Post #702321 16th Oct 2024 9:40pm
