I have a suspected broken front drivers seat control module.
I have no rake adjust or front seat squab height adjust. Swapping the switch panel with passenger makes no odds.
Swapping the control module with passenger sides means all drivers side switches work but only for a 5mm or so movement for each press of any of the seat switches. Which is better than not moving it at all Which is what I did have.
So why does it only move 5mm with each press, does the module need plugging in and configuring? It works fine when i swap it back to passenger seat.
When the suspected broke drivers seat module is plugged into the passenger seat, nothing works! That bit i dont fully understand!
I have an autel which won't connect on diagnostics to the seat module.
Any suggestions? Currently thinking new seat module just don't know if I need to program it! Cheers
James
