![]() | Home > In Car Electronics (L405) > Dim instrument cluster on a MY 2016 L405 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35588 ![]() ![]() |
check that battery to see if its up to powering all the electronics on start up.....it could be that after a period the voltage has increased...
pasha0305 Member Since: 09 Mar 2024 Location: London Posts: 10 ![]() ![]() ![]() |
Yes I noticed the same on mine today! Gonna check the battery voltage. Is it the main battery or the aux one that I should check? |
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 38 ![]() ![]() ![]() |
The main battery was replaced by the dealer this summer before I got the car. No low battery warnings whatsoever or related symptoms. Even the engine start/stop-function works right away (it wouldn't if the charge was too low).
Sometimes it works, sometimes it doesn't regardless if the car has been sitting for a longer period or not. The ambient light sensors (two dots on the bottom of the screen) don't seem to do a thing if I cover them up or aim a flashlight at them.
This issue seems to be related to some odd symbiosis with the automatic headlights/running lights. In the proper darkness/night time the manual brightness control seems to work as one would expect.
