![]() | Home > In Car Electronics (L322) > DAB radio module |
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 48 ![]() ![]() ![]() |
Any body ever changed there dab module and how did they do it any help would be great |
Thanks will give it a go when I find one for the right money |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 79 ![]() ![]() ![]() |
just be aware that there is less and less on Dab as more and more are migrating over to Dab+, I got the Invery and bluetooth from apps on the phone , there is a DaB module that gives you Dab+ but its around £500 as opposed to the £80 I paid for the Invery.....
Just as an update just changed DAB module not as easy as you think but job done and it works now 2012 Westminster 4.4 tdv8 |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 152 ![]() ![]() ![]() |
Excellent result 👍🏻 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 146 ![]() ![]() ![]() |
Hi Ash - can you (or anyone else) point me in the direction of the DAB unit on an L322 please ? Going to install a DAB+ as my old school DAB is kaput. |
It’s in the boot, left hand side as you look from the back. Remove the cover and the DAB module is at the bottom Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
Didn’t think you could add DAB+ to l322 2012 Westminster 4.4 tdv8 |
Thanks Beullie |
You can - with an adapter cable. The only thing you need to do to get it to function is to select DAB on the head unit, switch the display off then on and then turn the volume knob. I did it on my old L320 and it worked fine and lots of other L320 owners have done the same. |
That’s interesting where can you get this adapter cable from please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
Part nr is LR032814 |
Thanks
It replaces the power lead that goes to the existing DAB module. The wires are reversed for polarity. I need to find the DAB module on my L322, so will investigate over the next couple of days. |
