Home > General (L460 2022) > Fuel range messed up or is this by design?
Hoyboy
Just wondering whether everyone else’s car does this. It’s a MY24 L460 D350 and it’s the first time I’ve run it this low. It’s currently showing 29 miles of range left and the fuel light hasn’t even come on yet.
I struggle to believe that it’s meant to do this as my previous L405 Range Rover would be showing the warning at around 55 miles.
Does any one else’s do this or is there something wrong with the range countdown on my car?
Cheers
Post #701459 4th Oct 2024 11:32am
maybe its calculated that range from previous runs, did you just have a hard motorway journey? .. ... - .- -.
Post #701463 4th Oct 2024 11:46am
Hoyboy
Nah not particularly. It’s being driven the same way as all my previous cars with a mix or town and motorway driving at cruising speed. Definitely not being driven hard at all. Even the SVR I used to have would warn you at around 50 miles or range which is why I’m so confused. I’d understand if I was ragging it but I’m not.
Post #701468 4th Oct 2024 12:02pm
DJIT
I guess the way to test Stan's thought is to go into the Remote app, click on the most recent journey and see what MPG it says you were getting.
If its a really low, like 15MPG then as Stan says, it might still have nearly a couple of gallons (ie not enough to give you the alert).
If it says something around 30MPG+, you know for sure you have an issue.
Good luck!
Post #701480 4th Oct 2024 2:05pm
Hoyboy
I must have an issue then. These were the journeys the night before…
Post #701490 4th Oct 2024 4:11pm
Curious to know what the miles left will read tomorrow after the FF has had a nightful rest. ... - .- -.
Post #701498 4th Oct 2024 5:07pm
Hoyboy
I had to go out now and couldn’t be bothered to risk it. It dropped down to 15 miles remaining just inside the red zone with the light on. Filled it up to the first click and it took just over 77 litres.
The online manual says usable tank size is 80 litres. That don’t really make sense to me either. So the light only came on with 3 litres in tank remaining? Seems like it gave me no warning at all that there was pretty much nothing left.
Post #701499 4th Oct 2024 5:20pm
Renaco
Germany 2019 Range Rover Vogue SDV6 Corris Grey
Fuel level is mostly measured by a „swimming“ piece on an level arm.
Its position and how the arm is bent makes a lot of difference.
I had a new supercharged P525 in 2018 and it showed far less range than expected, then my garage opened the tank and bent the measurement gauge, that it was showing exact „reserve“ light once 15 Liters/100km left.
Maybe this can be done in the other direction on your car? RR Classic 1998-2005
MINI 40th 1999-now
RRS SDV6 2011-2014
RRS SDV6 HYBRID 2014-2018
RRS P400e 2017-2018
RRS P525 2018-2022
RR VOGUE 2022-2024
RR P550e 2024
Post #701736 7th Oct 2024 8:11pm
Bill
Hoyboy, my warning light comes on around 50 miles.
If these diesels run out of fuel it’s allegedly very bad news for the engines.
I would investigate if I were you. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #702163 14th Oct 2024 4:25pm
Hoyboy
Hmm that’s interesting,
It might be caused by that then. For reference I filled it up to the top a couple of days ago and it showed a range of 567 miles remaining. The needle didn’t budge on the fuel gauge until it was showing 452 miles remaining. Literally didn’t move at all for the entire time. I think actually drove around 80 miles in real terms before it moved.
Seems like it likes to overestimate how much is in there. I’m gonna try run it low again and see what happens. Didn’t get a chance to do it this week.
Post #702524 18th Oct 2024 8:37pm
Hoyboy
Yeah you’re right Bill really don’t wanna run it too low in case it actually runs out. That fact yours shows 50 miles remaining when the light comes on confirms my suspicions. Out of interest what does your car’s long term average mpg say?
I’m gonna test it again a few more times to see if it keeps doing it and if does I’ll take it in to get it looked at. Still confused on whether it’s the computer messing up or the physical float (or whatever it is) in the tank.
Post #702540 19th Oct 2024 12:22am
Bill
I’m not sure what the long term average is for sure, but guess it’s around 33.
As I posted the other day , I had some clear Belgium/lux motorway driving around 60-70mph and had 39 mpg.
Normally above 80/90 mph in France it drops to 30, Any faster goes down to 27-28. No lower.
Short trips are different.
ALL of my diesels , the mpg has improved with age & this one after 2 years is no different, I am seeing an improvement. Easily spotted by the fictional range after filling up.
When new the range after filling twas around 525 mile range, now showing 575 . As per all of the other cars the first fifty drops off after 10-20 miles or so.
Frankly on 15000 miles per year the Mpg tween 27 and 33 probably costs £500.00 and is really incidental to the cost of owning a FFRR, that said the difference tween petrol and diesel is not only the capital cost , but mpg of 22 against 33 is £1200-1300, more importantly if the end of the world is nigh, I reackon I can always find or store diesel, unlike petrol. Adblue might be harder to find! Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #702665 20th Oct 2024 11:28am
Hoyboy
So by chance I literally ran the car down to empty tonight. Fuel light came on at 28 miles again and it literally stayed at the top of the red until about 15 miles where it moved to the middle, it then stayed there until about 3 miles remaining and then out of nowhere it dropped like a rock all the way down to the bottom of the red zone. Got to the garage with it showing 1 mile left and filled it up to the first click.
Even though it was still above E, it filled up 80.18 litres which means the tank was basically completely empty and yet it was still not showing completely empty on the fuel gauge.
The way it just dropped out of nowhere makes it seem like the float or whatever is used to measure it is sticking and then moving in big jumps once the level drops low enough.
The fact it says on the capacities page in the user manual that the tank has a “usable” 80 litre capacity, does that imply there’s a hidden reserve?
Feels like the fuel light on this only comes on at the last minute and gives no warning at all compared to my previous Range Rover where you could have 0 miles remaining and when you fill it up there’s still 10 litres left.
Either way this whole exercise has made me not trust it even more and I wouldn’t be surprised if I did only have 1 mile of range left based on how much went in. Does this really not happen to anyone else?
Post #708823 10th Jan 2025 9:50pm
Hoyboy
Also noticed that since I ran it low yesterday it’s now messed the app up somehow. It’s show 100% full on the app but still shows the fuel low warning as well.
Post #708906 12th Jan 2025 1:04am
Rowdie
Yes sameish thing. The low fuel seems very over cautious !. Maybe this is a good thing !. Sometimes it comes off and them goes off again
Post #708972 12th Jan 2025 8:51pm
