Home > Maintenance & Mods (L405) > Start/stop button - just the cover |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 162 |
Sorry, I don't know the answer to your question, but the stop start, and other buttons on mine were in a gooy, sticky mess and after watching a youtube video I was able to clean them Using a Q tip and Isopropyl alcohol. They have a 'soft touch' coating which turns into a sticky mess. The alcohol allows you to carefully peel it off and reveal the hard plastic underneath with symbols still intact.
3rd Oct 2024 7:25am |
Dartanjang Member Since: 03 Nov 2022 Location: Vasteras Posts: 15 |
Good suggestion. I will check it out and see if that proves to be satisfactory.
3rd Oct 2024 7:33am |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 158 |
These *may* be the part numbers...
8th Oct 2024 3:07pm |
Thanks for the suggestions JD. I checked them out and they seem to be for the entire switch. The search for the cap only continues.
9th Oct 2024 8:19am |
I doubt you will find cap only.
9th Oct 2024 10:24am |
