Home > Maintenance & Mods (L405) > Start/stop button - just the cover
Dartanjang
Sweden 2015 Range Rover Autobiography SDV8 Carpathian Grey
Has anyone found the button cover as a spare part? And with an LR part no? It's just the plastic cover that gets worn and that I want to replace. I can only find the entire switch assembly everwhere I look.
I am not interested in the chinese stickers that are placed on top of the original. I want to retain the illumination and restore it to its original state.
Does anyone know where this can be found?
BR
Anders
Post #701343 3rd Oct 2024 7:43am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Sorry, I don't know the answer to your question, but the stop start, and other buttons on mine were in a gooy, sticky mess and after watching a youtube video I was able to clean them Using a Q tip and Isopropyl alcohol. They have a 'soft touch' coating which turns into a sticky mess. The alcohol allows you to carefully peel it off and reveal the hard plastic underneath with symbols still intact.
Check out 'Sticky Buttons' on youtube. Hopefully it might work for you
Post #701346 3rd Oct 2024 8:25am
Dartanjang
Good suggestion. I will check it out and see if that proves to be satisfactory.
//Anders
Post #701347 3rd Oct 2024 8:33am
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
These *may* be the part numbers...
LR094038 LR037611
https://a.co/d/31l43td
For $42 - it may be worth taking a flyer 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #701780 8th Oct 2024 4:07pm
Dartanjang
Thanks for the suggestions JD. I checked them out and they seem to be for the entire switch. The search for the cap only continues.
BR
Anders
Post #701817 9th Oct 2024 9:19am
JDGeorgia
I doubt you will find cap only.
You could get a pre-owned unit and scavenge just the button. To swap them I believe you will have to pull the unit anyway. Getting just the cap out of the unit seems like a decent way to destroy some plastic tabs.
Why the reluctance to just pop it with a trim tool and swap the unit? 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #701824 9th Oct 2024 11:24am
