Home > General > C Pillar Interior Trim Installtion Help
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
I could hear a creaking trim in the back of my TDV8 so had a look just now and the passenger side C Pillar interior trim isn't clipped in properly, its the piece with the speaker grill incorporated into it.
It looks like it pushes into place as from the back of the car and can see 2 location pegs but it also seems a little reluctant.
Before I use hand force ans snap a pin / guide off it does anyone have the removal / install procedure or has anyone done this such that they can give me some guidance please?
Thanks
Carl
Post #77114 22nd Aug 2011 5:18pm
pretlove
you need to make sure the seat belt part meets up with the slider or else it wont clip on "RANGEISM WILL NOT BE TOLERATED"
Post #77115 22nd Aug 2011 5:19pm
carlos50
Have I described it incorrectly, I mean after the doors, the pillars that the tailgate closes into?
I thought this was C Pillar?
Post #77117 22nd Aug 2011 5:26pm
pretlove
your more than likely correct i was thinking you meant the other part.....in that case it just pops on just make sure its lined up "RANGEISM WILL NOT BE TOLERATED"
Post #77119 22nd Aug 2011 5:38pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
If its the one in the boot space I took mine off at the weekend to try and find where water is coming into the boot area. Big Cry
It is just held in place with plastic clips.
These can be replace (I assume) as they are not part of the main section.
I just lined the clips up with the holes and knocked them into place. Thumbs Up
Post #77136 22nd Aug 2011 6:40pm
M44K TS
I could be wrong, but I think it's the D pillar trim. As Bob says, it's just held on by trim clips, might be that a couple are broken if it's been off before. That is if it's the same as my 2003 was. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #77139 22nd Aug 2011 6:53pm
carlos50
Thanks gents. It is still attached but the 2 most rearward pins are not clipped in so the trim is rattling. I tried to push them in but they seem reluctant to locate, perhaps the whole trim needs to be removed and re positioned before i apply hand pressure and snap the 2 clips?.
Does the trim just pull away from the pillar?.
Post #77220 23rd Aug 2011 12:01pm
Bob the B
Yes. I think there are 4 or 5 clips holding the trim in place and another one that slides onto the roof trim.
Post #77258 23rd Aug 2011 4:07pm
wardpg
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I had the same problem with mine. If you look carefully at the clips that are on the panel you will see that they are excentric so you need to turn them so that they line up with the corresponding holes. My panel came loose and i spent ages trying to get it back. it was only when my son had a look that we found out what the problem was -went back easy when we lined the clips up properly-hope this helps Ex D1, D2, D3 owner now 2008 TDV8 Vogue SE
Post #77524 25th Aug 2011 11:30am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Yes this is the D pillar and is held on by 4? press stud clips. If you break some don't worry they are cheap to replace. To remove the trim work your fingers under the edge next to the rear quarter window and pull firmly away. As you pull the edge under the boot door seal will role out from underneath. Don't pull too far out until you have disconnected the speaker wires... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #77658 26th Aug 2011 8:35am
