Home > General > C Pillar Interior Trim Installtion Help |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
you need to make sure the seat belt part meets up with the slider or else it wont clip on "RANGEISM WILL NOT BE TOLERATED"
22nd Aug 2011 5:19pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Have I described it incorrectly, I mean after the doors, the pillars that the tailgate closes into?
22nd Aug 2011 5:26pm |
your more than likely correct i was thinking you meant the other part.....in that case it just pops on just make sure its lined up "RANGEISM WILL NOT BE TOLERATED"
22nd Aug 2011 5:38pm |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
If its the one in the boot space I took mine off at the weekend to try and find where water is coming into the boot area.
22nd Aug 2011 6:40pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
I could be wrong, but I think it's the D pillar trim. As Bob says, it's just held on by trim clips, might be that a couple are broken if it's been off before. That is if it's the same as my 2003 was. 2006 Mercedes CLS
22nd Aug 2011 6:53pm |
Thanks gents. It is still attached but the 2 most rearward pins are not clipped in so the trim is rattling. I tried to push them in but they seem reluctant to locate, perhaps the whole trim needs to be removed and re positioned before i apply hand pressure and snap the 2 clips?.
23rd Aug 2011 12:01pm |
Yes. I think there are 4 or 5 clips holding the trim in place and another one that slides onto the roof trim. |
23rd Aug 2011 4:07pm |
wardpg Member Since: 26 Jul 2008 Location: Preston Posts: 76 |
I had the same problem with mine. If you look carefully at the clips that are on the panel you will see that they are excentric so you need to turn them so that they line up with the corresponding holes. My panel came loose and i spent ages trying to get it back. it was only when my son had a look that we found out what the problem was -went back easy when we lined the clips up properly-hope this helps Ex D1, D2, D3 owner now 2008 TDV8 Vogue SE |
25th Aug 2011 11:30am |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
Yes this is the D pillar and is held on by 4? press stud clips. If you break some don't worry they are cheap to replace. To remove the trim work your fingers under the edge next to the rear quarter window and pull firmly away. As you pull the edge under the boot door seal will role out from underneath. Don't pull too far out until you have disconnected the speaker wires... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
26th Aug 2011 8:35am |
