![]() | Home > Technical (L322) > 2011 Front parking sensor recessed |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
I think removing the bumper is your best option, it’s not very difficult and once removed gives you good access to what you need. It’s possible the plastic retainer that hold the sensor has detached from the rear of the bumper thus it’s not being held in place. If so some plastic glue should do the trick, if you get it where you are there’s a two part JB Weld product called “plastic weld” that’s very good.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
Removing the bumper cover is an easy after you find the 2 hidden screws (which unfortunately I can’t remember where they are).
WozaD Member Since: 06 Sep 2024 Location: JHB Posts: 3 ![]() ![]() ![]() |
Thank you for the responses I was hoping for a lazy quick fix solution but looks like I have some work ahead of me this weekend. Which doesn’t seem to be too hard to do.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi, there's a pretty good tutorial on removing the front bumper on Youtube, not tried it myself but seems simple enough, I was going to do soon to have it repainted.
Thank you Andy, will give it a crack this weekend. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
I've used the YT vid when I was replacing a camera on my 2011, dropped the trays, and tried leveraging/flexing the bumper and almost needed stitches stuffing my oversized hand up the gap!
