Home > Technical (L322) > 2011 Front parking sensor recessed
WozaD
South Africa 2011 Range Rover Vogue SE TDV8 Ipanema Sand
Hi all
I recently purchased a 2011 tdv8 and now understand why people love these cars. Coming from a Toyota of a similar year, it’s worlds apart.
My question is, one of the parking sensors “second front the right” is recessed, basically pushed into the bumper. I had a look this past weekend to see if I could somehow make a plan without removing the bumper but to no avail.
The sensor still works but it working on the wrong side of the bumper 😂 is there any advise from anyone on how I can get access to the sensor without removing the bumper or taking the car in.
I tried going through the wheel well, but the sensor is too far for my arms to reach 😂 I tried removing the front grill but wasn’t successful.
Any help or advise is greatly appreciated.
Post #701116 30th Sep 2024 6:17am
Scouse Exile
I think removing the bumper is your best option, it’s not very difficult and once removed gives you good access to what you need. It’s possible the plastic retainer that hold the sensor has detached from the rear of the bumper thus it’s not being held in place. If so some plastic glue should do the trick, if you get it where you are there’s a two part JB Weld product called “plastic weld” that’s very good.
Jon
Post #701120 30th Sep 2024 9:17am
cass
Removing the bumper cover is an easy after you find the 2 hidden screws (which unfortunately I can’t remember where they are).
I suppose this is a 1/2 answer!
Post #701128 30th Sep 2024 11:11am
WozaD
Thank you for the responses I was hoping for a lazy quick fix solution but looks like I have some work ahead of me this weekend. Which doesn’t seem to be too hard to do.
Thanks again
Post #701170 30th Sep 2024 6:43pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, there's a pretty good tutorial on removing the front bumper on Youtube, not tried it myself but seems simple enough, I was going to do soon to have it repainted.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #701268 2nd Oct 2024 8:26am
WozaD
Thank you Andy, will give it a crack this weekend.
Post #701301 2nd Oct 2024 5:29pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I've used the YT vid when I was replacing a camera on my 2011, dropped the trays, and tried leveraging/flexing the bumper and almost needed stitches stuffing my oversized hand up the gap!
Not as onerous as you'd think, and probably the best time of year to do it. Probably give all the spring nuts that the screws clamp into a good does of Bilt Hamber Hydrate80 and perhaps some kind of anti-seize/sheep juice anti-rust.
Cheers
Stephen Thumbs Up Formerly happymadison1978
Post #701667 6th Oct 2024 10:09pm
