![]() | Home > Maintenance & Mods (L405) > 5.0 Timing Chain Guides…. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Is there a year when LR fixed the chain guide issues on the 5.0 SC please?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
I've heard of failures of 15/16MY SVR's...
Ok, thanks. Just wondered if I had to still bear it in mind on later L405 and L494. I understand it’s expensive to sort if you don’t do it yourself.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 614 ![]() ![]() ![]() |
My understanding was that the spec of the guides were changed in the 5.0 at around the time the L405 came out and the problem largely went away. Still a moving part so there will always be failures at some stage...but no longer "common". Mike - MPx
