![]() | Home > Maintenance & Mods (L405) > Headlight bulbs/LEDs? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
@will, yours is a L322 ?
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1687 ![]() ![]() ![]() |
Yes, to get access you’ll need to disconnect a few bits & pull (literally) the airboxes out both sides on the V8, but its mostly just big lumps of plastic, which are easy enough to get back together.
Kev the Rev Member Since: 07 Jan 2024 Location: Ripon Posts: 44 ![]() ![]() ![]() |
Hi Gremlin
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 518 ![]() ![]() ![]() |
Stan sorry did mean to say l322 gone just in the process of getting a l405 |
Yes, remove all the screws & disconnect the electrical plugs, remove top of air boxes and filters, then the lower part of the boxes simply pulls out of the wing and upwards, then you have full and easy access to the two large rubber bungs. Look inside and you will see there is a big locking ring to rotate about 30 degrees to lock/unlock, there’s a picture on here somewhere, perhaps Stan can find it?
Hi Gremlin
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 755 ![]() ![]() ![]() |
That’s mine in and ready for some darkness! Took my guy 20mins to fit them both!! 2014 vogue se |
Chefkenmore
Went out for a run tonight to “try” the new bulbs, fantastic improvement but mine were flickering! Went out, had to re switch on to bring them back on! Wonder if the connectors haven’t been pushed home correctly or faulty bulbs??
@chefkenmore:
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2659 ![]() ![]() |
Some bulbs are fitted with a switch for different settings to overcome flickering. |
Thanks Gremlin, can I change any settings with my Gap?
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
I've been running these for over a year now and they are fantastic...
