Home > Maintenance & Mods (L405) > Headlight bulbs/LEDs?
Page 2 of 3 <123>
Kev the Rev
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
Plug and Play?
I don't think so, I gave up after an hour.
Looks like an engine out job
Just joking but it's the first time I've ever had a serious look under the bonnet
Flip, you can't even get a hand in there
Post #701053 29th Sep 2024 7:39am
@will, yours is a L322 ?
didnt have leds when i had my 2008 so cant help on that.. ... - .- -.
Post #701054 29th Sep 2024 8:23am
Gremlin500
Yes, to get access you’ll need to disconnect a few bits & pull (literally) the airboxes out both sides on the V8, but its mostly just big lumps of plastic, which are easy enough to get back together.
Difficulty is only about 2/5, an hour tops from start to finish.
Time to get brave & have a go, you’ll be so chuffed with yourself afterwards! “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #701055 29th Sep 2024 8:26am
Kev the Rev
Hi Gremlin
some comments say it's easier if you separate the top of the airbox from the bottom, maybe this makes a bit more wiggle room?
Post #701059 29th Sep 2024 8:47am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Stan sorry did mean to say l322 gone just in the process of getting a l405
Post #701061 29th Sep 2024 9:03am
Gremlin500
Yes, remove all the screws & disconnect the electrical plugs, remove top of air boxes and filters, then the lower part of the boxes simply pulls out of the wing and upwards, then you have full and easy access to the two large rubber bungs. Look inside and you will see there is a big locking ring to rotate about 30 degrees to lock/unlock, there’s a picture on here somewhere, perhaps Stan can find it?
Be very careful to align the square part of the new bulb with the multitude of little finger springs, so you don’t bend any, or you will curse. A good light helps, it’s surprisingly dark in there.
Good luck, and report back! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #701062 29th Sep 2024 9:05am
Kev the Rev
Hi Gremlin
mission accomplished, thanks for your help. Took me longer than an hour but was going nice and steady as I don't like forcing things
At least I know how to change the air filters now
It's a bit scary how much stuff is packed under the bonnet of the SDV8, don't think I would like to have to do a big job
Post #701072 29th Sep 2024 12:18pm
Gremlin500
Well done! Bow down
I hope you’re feeling suitably smug & self-accomplished, I bet it won’t get dark soon enough tonight!
Rolling with laughter Rolling with laughter Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #701080 29th Sep 2024 3:44pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
That’s mine in and ready for some darkness! Took my guy 20mins to fit them both!! 2014 vogue se
Post #701158 30th Sep 2024 3:22pm
Kev the Rev
Chefkenmore
Tried mine out last night for the first time and they are amazing, they're what the car should have had from new
Don't think you'll be disappointed
Post #701160 30th Sep 2024 3:29pm
chefkenmore
Went out for a run tonight to “try” the new bulbs, fantastic improvement but mine were flickering! Went out, had to re switch on to bring them back on! Wonder if the connectors haven’t been pushed home correctly or faulty bulbs??
Big Cry Big Cry Big Cry 2014 vogue se
Post #701259 1st Oct 2024 7:04pm
Gremlin500
@chefkenmore:
Your car is 2014, Kev’s is 2016, so there may be differences in what is enabled in config.
This may help:
Worth getting the Vgate, cheap as chips and a great bit of kit, with the App on your phone for diagnostics, and very good for monitoring DPF regens for a later diesel if you upgrade at some point. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #701263 1st Oct 2024 10:15pm
GraemeS
Some bulbs are fitted with a switch for different settings to overcome flickering.
Post #701265 2nd Oct 2024 12:15am
chefkenmore
Thanks Gremlin, can I change any settings with my Gap?
The back of my old bulb says D3S? LEDs are D1S would that mean Ive got the wrong bulbs??
Just bought some new bulbs from amazon at £80! Thought the ones I have could be faulty ! They are also D1S??
Hope I can get them to work as the improvement is great!
David 2014 vogue se
Post #701269 2nd Oct 2024 7:31am
knwatkins
I've been running these for over a year now and they are fantastic...
https://www.aliexpress.com/item/1005005227734418.html Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #701723 7th Oct 2024 5:52pm
Page 2 of 3 <123>
