Home > Technical (L322) > B12A9-62 Fault
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
B12A9-62 Fault
Was searching for faults on my gap IID and found this code that wouldnt clearel. Steering column tilt sensor. I can adjust the column using the stalk but the memory function doesn't work. Has anyone had the same problem and had a solution?
Post #700157 15th Sep 2024 5:54pm
