Home > Technical (L322) > Suspension Fault vehicle lean when cornering with ACE
karllap
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Hi,
I am getting an amber fault when cornering but it is quite intermittent and the suspension still seems to be working fine
I have a 2014 Autobiography with ACE and before I start to spend lots of money on diags etc I just want too check the fluid levels
Is it on the right as you look at the engine in an oval shape reservoir? If so, it does look a little low but very difficult to see through the side against the min mark
Where do I get this fluid in the UK and what is the smallest I can get as it only seems to be slightly low.
Post #700112 14th Sep 2024 11:30am
