Home > Maintenance & Mods (L322) > Squeak
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Squeak
Right let's see what you all think...
Intermittently when pulling away after being stationary for a period of time i'm getting a squeak which gradually speeds up as i accelerate, although doesn't seem to match what i perceive to be wheel speed but then stops altogether.
Sounds like the back end somewhere, i was thinking brake related but have stripped and cleaned all the brakes (but not the drums) mud shields are in place and solid.
over to you....
Post #700067 13th Sep 2024 3:38pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
It could be the hand brake shoes catching. The shoe retaining pins have a habit of pulling through the backplates, which causes the shoes to catch the drum
Post #700069 13th Sep 2024 5:12pm
Discofish
Cheers,
will whip the wheels off and give it a look Smile
Post #700167 16th Sep 2024 7:57am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Add one for rear drums. I had the retaining clips for the shoes pop out on one side, the spring and the retainer were spinning in the drum. Sounds ranged from squeak to screach on and off.
Luckily the backing plate wasn't rusty or damaged, just seems to have worked loose, reseated and been good ever since, over a year ago now.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #700172 16th Sep 2024 9:16am
