![]() | Home > In Car Electronics (L322) > Stereo Having a Nervous Breakdown |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
I was listening to music through the aux input while driving yesterday when I noticed the stereo didn't respond to volume changes either on the steering wheel or the main on/off switch. I then noticed it kept playing music even when I turned the stereo off!
Everything there is as dry as a bone. There is not even a sign of previous ingress or corrosion. I guess the plastic sheet fix they introduced in that area years ago must be working.
Happened again today. Just pulled over and shut the engine off and waited for the nav screen to shut down. All OK again after restart. No obvious fault codes. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35492 ![]() ![]() |
Check the battery terminal connections and make sure they are tight.
No, I've had the car 7 years now and I never had the issue before. Now twice since the new alternator and battery, the first time about 7 weeks after fitting and the second time about 7 weeks after the first. Will check the terminals.
Terminals are secure. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
