Home > Maintenance & Mods (L405) > Towing electrical issue
johnny boy
United Kingdom 2016 Range Rover Autobiography TDV6 Barolo Black
Fully loaded the trailer, connected up but no electric’s.
Tried two different 13 to 7pin adapters, two different light boards, checked both fuses but still nothing, no indications on dash either.
Tried my reader but no option av.
The tow bar and electrics were professional fitted by previous owner but never issued.
Would I be right in thinking the car needs to be coded for trailer use, especially with led lights.
Is there any way around it as I need to leave at 7 in the morning.
Cheers
John
Post #699081 29th Aug 2024 6:08pm
diesel Dave
The electrics should be plug and play for normal trailer, caravan use, but I’m pretty sure they wont work with LED lights.
Post #699090 29th Aug 2024 9:38pm
V8 Bob
LED’s normally will work but the car won’t recognise them so you won’t be told that the trailer is indicating. This is caused by the reduced voltage draw compared to a normal bulb.
Checking the trailer electrics fitted to a car is I believe part of the mot test for vehicles thus fitted. Most trailer light issues are earth related hope this he.ps. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #699092 29th Aug 2024 10:14pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I have this when I connect my caravan, there are bulbs to the caravan, if I leave the engine running when I connect the lights, they don't come on until I turn the car off and then start the car.
Or connect the electrics when then the car is turned off it may work for you. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #699098 30th Aug 2024 7:24am
johnny boy
Finally had a bit more time.
The trailer socket on the car is showing 12.9 with the meter, however when i connect the trailer or any adapter there is no power from the socket.
Strange one, i'll take the socket apart next week and try and find whats going on.
Should i have the trailer symbol on the instr panel before starting the engine when the cars doing self check,2016 Autobiography.
Cheers
Post #699250 1st Sep 2024 2:25pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
The 13 pin socket is tested on an MOT, the 7 pin socket is not.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #699259 1st Sep 2024 4:50pm
johnny boy
Ok just an update.
Cracked it.
Removed the towing socket and stripped it down completely.All the connections were good but when I took the socket apart the internals clip into the outer part of the socket. One of the clips wasn’t made so when I plugged the trailer lead in it was moving the internals about a couple of mm and was not fully connecting😁
Post #699491 4th Sep 2024 4:33pm
