Home > Maintenance & Mods (L405) > Towing electrical issue |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 449 |
The electrics should be plug and play for normal trailer, caravan use, but I’m pretty sure they wont work with LED lights. |
29th Aug 2024 10:38pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 352 |
LED’s normally will work but the car won’t recognise them so you won’t be told that the trailer is indicating. This is caused by the reduced voltage draw compared to a normal bulb.
29th Aug 2024 11:14pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1165 |
I have this when I connect my caravan, there are bulbs to the caravan, if I leave the engine running when I connect the lights, they don't come on until I turn the car off and then start the car.
30th Aug 2024 8:24am |
johnny boy Member Since: 26 May 2024 Location: bristol Posts: 8 |
Finally had a bit more time.
1st Sep 2024 3:25pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 101 |
The 13 pin socket is tested on an MOT, the 7 pin socket is not.
1st Sep 2024 5:50pm |
Ok just an update.
4th Sep 2024 5:33pm |
