Home > Technical (L322) > Crankshaft pulley out of alignment
kjmeijer
Netherlands 2011 Range Rover Supercharged 5.0 SC V8 Buckingham Blue
After a few years without a Fullfattrr I bought a very nice 2011 5.0SC with about 145000 km last winter.
Timing chains where renewed by the specialist who sold me the car and it drove without problems. Last month my local LR specialist noticed that the crankshaft pulley was out of alignment and that the auxiliary belt was "eaten" slowly. They could not diagnose this problem without some major surgery so I asked the seller if they had any idea because they maybe did something wrong while changing the timing chains.
Now they want to solve the problem by changing the crankshaft bolt by a LR011952 bolt. My technical knowledge about these things is very limited. Any ideas about this bolt changing solution?
 2011 RR 5.0 SC & 2021 New Defender D300
Post #699069 29th Aug 2024 2:31pm
RobErica
Netherlands
Are you sure it is the crankshaft pully? In my opinion a bolt doesnt do anything with alignment, and if it were loose the pully would be movable. Could be another pully as well, maybe the shaft of the waterpump?
Post #699100 30th Aug 2024 8:38am
kjmeijer
I am also not sure about the bolt solution and hope to get some ideas of other causes. 2011 RR 5.0 SC & 2021 New Defender D300
Post #699106 30th Aug 2024 9:11am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I doubt it's the crankshaft pulley, that would take quite a whack to move that and as pointed out, changing the bolt would not impact that.
I'd suggest looking at the other pulleys first, if they've had one off for some reason and put it back on crooked by leaving some crud on the mating surfaces that would do it.
May just be the parallax but it looks to me from the picture that the fan pulley looks like its tilted forwards at the top, that may be causing your problem.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #699108 30th Aug 2024 10:47am
GraemeS
The tensioner is usually the one that gets out of alignment due to wear in its pivot.
Post #699141 30th Aug 2024 8:42pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
that bottom pully looks like its not mounted square or the shaft is broken RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #699146 31st Aug 2024 5:43am
kjmeijer
Some news: the mechanic can see that the crankshaft pulley is not quite right. They can do two things:
1. install a new crankshaft pulley. The cost of this is €366.14. However, they cannot say with certainty that this will solve the problem, since there is currently an original part on it.
2. They can also install a different belt with one tooth less. This means that it will no longer be affected by the pulley.
Option 2 does not feel right for me. Any ideas about option 1? 2011 RR 5.0 SC & 2021 New Defender D300
Post #699323 2nd Sep 2024 4:36pm
RobErica
Netherlands
I wonder how a fixed pully can get out of allignment. There must have been some violent force to do that imo.
And for the second option, the belt would also be eaten, maybe slower, but still.
Did he notice the crankpully out of allignment with engine running?
Post #699324 2nd Sep 2024 4:57pm
kevinp
Wouldn't it be best to get a straight edge and see which one is out of alignment. Does one wobble with the engine running?
Post #699325 2nd Sep 2024 5:11pm
JayGee
It's not uncommon for crankshaft pulleys to be rubber decoupled with the outer drive ring and the inner shaft seperated by rubber. If the rubber deteriorates it can cause the outer ring to run eccentricly. 2012 TDV8 Vogue (L322)
Post #699331 2nd Sep 2024 6:00pm
dhallworth
The crankshaft pulley uses a special tool to pull it off the crank and when refitting the tool is reversed and the pulley is pushed onto the crankshaft.
I wonder if they've not pushed it back onto the crankshaft far enough using the special tools.
However, that bolt is TIGHT. The official figures are 200nm plus a further 270 degrees. When I did mine it was locked using the official tools and I was using a 5 foot 3/4" breaker car to tighten it. I would have thought with it being that tight it might have seated the pulley properly if it wasn't done so with the proper tools.
Before you start buying a new pulley I would remove the old one and have a proper look at it and refit it properly to see if it lines up any better.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #699338 2nd Sep 2024 7:01pm
GraemeS
If the pulley is out of alignment or is moving enough to cause the belt to be damaged then the outer section must have moved due to the rubber deteriorating and therefore a new pulley should be fitted. If not replaced then the movement will get worse.
Fitting is achieved using a bolt such as the old bolt with the thick spacer removed. Note that there is a thin washer between the end of the crankshaft and the inside of the pulley which gets bent to a D shape during fitting as the crankshaft has a flat to ensure that the pulley can't rotate on the shaft. Whilst I purchased a new washer, the old one was firmly wedged into the pulley so I didn't change it when I R&R'd mine's pulley.
Post #699352 2nd Sep 2024 8:59pm
kjmeijer
Thanks for all the info and thoughts! The pulley is not wobbling wenn the engine is running.
I think I will let them put on a new pulley with special attention to the fitting. 2011 RR 5.0 SC & 2021 New Defender D300
Post #699358 3rd Sep 2024 4:53am
RobErica
Netherlands
If you do, just replace the waterpump as well, and double check all idlers and tensioners. I seriously doubt the problem is the crankshaft pully.
Post #699385 3rd Sep 2024 11:50am
knares
any news on this RR 2005 4.4 petrol
Post #703400 30th Oct 2024 7:53am
