Home > Technical (L322) > Crankshaft pulley out of alignment |
RobErica Member Since: 16 Nov 2023 Location: Loosbroek Posts: 38 |
Are you sure it is the crankshaft pully? In my opinion a bolt doesnt do anything with alignment, and if it were loose the pully would be movable. Could be another pully as well, maybe the shaft of the waterpump? |
30th Aug 2024 8:38am |
kjmeijer Member Since: 19 Jul 2017 Location: Dalfsen Posts: 17 |
I am also not sure about the bolt solution and hope to get some ideas of other causes. 2011 RR 5.0 SC & 2021 New Defender D300 |
30th Aug 2024 9:11am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
Hi, I doubt it's the crankshaft pulley, that would take quite a whack to move that and as pointed out, changing the bolt would not impact that.
30th Aug 2024 10:47am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
The tensioner is usually the one that gets out of alignment due to wear in its pivot. |
30th Aug 2024 8:42pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
that bottom pully looks like its not mounted square or the shaft is broken RR 2005 4.4 petrol
31st Aug 2024 5:43am |
Some news: the mechanic can see that the crankshaft pulley is not quite right. They can do two things:
2nd Sep 2024 4:36pm |
I wonder how a fixed pully can get out of allignment. There must have been some violent force to do that imo.
2nd Sep 2024 4:57pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1215 |
Wouldn't it be best to get a straight edge and see which one is out of alignment. Does one wobble with the engine running? |
2nd Sep 2024 5:11pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
It's not uncommon for crankshaft pulleys to be rubber decoupled with the outer drive ring and the inner shaft seperated by rubber. If the rubber deteriorates it can cause the outer ring to run eccentricly. 2012 TDV8 Vogue (L322) |
2nd Sep 2024 6:00pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 |
The crankshaft pulley uses a special tool to pull it off the crank and when refitting the tool is reversed and the pulley is pushed onto the crankshaft.
2nd Sep 2024 7:01pm |
If the pulley is out of alignment or is moving enough to cause the belt to be damaged then the outer section must have moved due to the rubber deteriorating and therefore a new pulley should be fitted. If not replaced then the movement will get worse.
2nd Sep 2024 8:59pm |
Thanks for all the info and thoughts! The pulley is not wobbling wenn the engine is running.
3rd Sep 2024 4:53am |
If you do, just replace the waterpump as well, and double check all idlers and tensioners. I seriously doubt the problem is the crankshaft pully. |
3rd Sep 2024 11:50am |
any news on this RR 2005 4.4 petrol
30th Oct 2024 7:53am |
