Home > Maintenance & Mods (L322) > Kingbolen ediag code reader. Bargain??
chiefracing
Like most, having bought an L332 Im looking for a code reader. Just watched this vid
?si=O19sI8wD3yWxkDmW
Anyone used it/have opinions?
Seems a cheap option
Post #699033 29th Aug 2024 6:20am
andygts
I've just bought a topdon topscan, very similar by the looks of it and similar price, cheaper if you shop around.
It will plug into just about any car with an OBD2 plug. It also has a fault code lookup and lists the most common fixes for that code. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #699042 29th Aug 2024 8:37am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Just out of couriosity I ordered one so I can compare it with the IIDtool. Hardly can believe that a OBD scanner for £50 can do more then read faults but let's see.
Post #699152 31st Aug 2024 7:15am
chiefracing
Ansi, please let us know how it goes. For £50 odd you wouldnt expect as much as the vid shows. Shame its £19 pa to keep oil reset active though.
Post #699160 31st Aug 2024 9:13am
Ansi
I will, but I'm travelling to Spain next Saturday and won't be back before the end of October. I doubt that the tool will reach me by Friday. So patience is required. Very Happy
Post #699228 1st Sep 2024 9:48am
