Home > General > How long have you owned your Range Rover(s) for?
Page 1 of 5 12345>
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I've had mine for 10 years now. Done just over 41000 miles in it (now on 86000 miles) serviced at a local indy every year apart from 1 during lockdown. Changed brake pads and discs myself a few years ago. Changed battery twice. Drop links and control arms changed out. Changed coolant tank to sort out low level (didn't work so live with it). Had rear arches done about 5 years ago ( rust starting to reappear so need to get them done properly along with the sill rears🙄).
All in all it's been great. I was only going to keep for a year. I'm now in a position to get an L405 but my indy says to keep hold of this one. What to do🤔? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #661168 6th Apr 2023 8:13am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
15 years here 54 plate TD6 - my view is if you have a good one, hang onto it
Post #661173 6th Apr 2023 8:56am
JMC
Bought my first L322 new in Feb 2009 - TDV8 Vogue. Did something like 160k miles in that one before replacing it with the current (2012) L322 TDV8 Westminster which I bought from a main dealer in Aug 2021 with only 42k miles on the clock. Didn't even consider an L4xx. Expecting to keep this one for the next decade too! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #661174 6th Apr 2023 8:57am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Had mine for 10 years and still going strong for an old un, she will be 20 years old this year.
RR had 85k when bought it and just turned 127k miles now.
If I can keep the tin worm at bay she will last for years longer.
As said before, if your happy with it and have a good one, keep it. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #661178 6th Apr 2023 9:09am
mjdronfield
Longest I’ve ever kept a car, since Jan 2016. Only done about 16000 miles in it. On 98k now.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #661248 6th Apr 2023 5:33pm
Andy S
Bought my L322 in 2013, 2010 3.6 facelift model VSE on 36000 miles, kept it 4 years and chopped it in on 77000 miles.
The L405 was bought in 2018; 4.4 VSE on 23000 miles. Still have it, currently on 57000 miles and no wish to get rid. This one’s a keeper and 4.5 years is already the longest I’ve ever kept a car.
Post #661249 6th Apr 2023 5:50pm
TDV8 Paul
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Will have had mine 3 yrs in may, bought it on 145k, now on 195k, had new turbos at 180kish and an alternator, new front air struts and some arms, but she’s like my Swiss Army knife and I wouldn’t be without it, drives around town beautifully, does our 1-2 trips a year to Cornwall, Alton towers in total comfort and tows the horse happily. I absolutely love it 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #661254 6th Apr 2023 7:32pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
I'm a long way behind you all having owned my 2012 Westminster since 4 January this year. I have always loved the shape of an L322 and wanted a grey one with black leather and low miles. I got mine with 53750 on it and I'm loving it. It was cherished by its last owner who did just 18000 miles in over 6 years. He changed the batter and starter motor in 2021. Belts and tensioners have also been done as has water pump.
I'm getting diff oils done and undersealing and cavity injection. At the same it will get a check over. Arches need a minor tidy and they will be done before the winter. Wheel refurb on the list too. I love the driving position which is so different from my M5. Planning to keep both for the foreseeable future.
Post #661260 6th Apr 2023 8:50pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Had mine for 11 weeks, done more works miles than personal so far and it has been a fabulous place to be, especially when I'm getting paid to go driving it First time FFRR owner
Post #661261 6th Apr 2023 8:57pm
bobsin
2004 Range Rover Vogue Td6 Epsom Green
8 years. 2004 TD6. Not much i haven't had to spanner on it. Just had rear arches and sill rears repaired, all rot cut out and new steel let in. then she failed mot with rear sub frame rot. Did the front sub 2 years ago, not too bad a job, rear is a different prospect, sourced a rear sub frame, repairs arranged, but if anything else big is needed, she's dead.
Post #661267 6th Apr 2023 10:22pm
Had the current one for over 2 years now - Craig keeps it perfect for me. My "MO" is buy at 5 years old 60k miles, run for 5 years (to 120k) and then repeat. Hasn't quite worked out like that. First one was a complete mare and had to go - but still persevered for 60k over 4 years. Second was perfect for 5 years. Third was really very good for 4 years until it suddenly wasn't (chains went) at a bad period for me so needed to swap it out sharp rather than wait for a repair. And so on to the SVAD bought at only 4 years old and 52k - perfect so far so may have to keep this one for 6 years or more to make up for the losses! Mike - MPx
Post #661273 6th Apr 2023 11:06pm
Thumbs Up Thumbs Up Thumbs Up Bow down
Post #661274 6th Apr 2023 11:09pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Old n New(er)
Restored my '72 classic 24 years ago and 38000 trouble free miles later, I still love it.
Had the Westie 4 years now for towing longer distances in comfort. Effortless! Forty years of progress. 1972-2012
Post #661282 7th Apr 2023 6:03am
TJH1985
United Kingdom 2007 Range Rover Vogue SE TDV8 Java Black
Had the L322 for 5 years (50 -> 100k) and the L405 coming up on 4 years so far (32k -> 58k) but starting to look at a replacement, mainly because I have a 5.0 itch I might need to scratch. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #661290 7th Apr 2023 7:06am
11 years for my TDV8, 1 year for my SC. Got - 2017 SDV8 Autobiography in Loire Blue
Post #661291 7th Apr 2023 7:07am
Page 1 of 5 12345>
