Home > Technical (L322) > Audio Amplifier Module fault codes B1A01-13 & B1A02-13
bearhouse
United Kingdom 2010 Range Rover Autobiography 5.0 V8 Santorini Black
Hi All,
I wonder if someone can kindly help... Amongst other faults, I have Audio Amplifier Module fault codes B1A01-13 & B1A02-13 Speaker Circuits 1 & 2 Permanent Faults. Has anyone had these faults? Can anyone suggest where to look. Has anyone fixed these issues? I have a 2010 5L V8 Autobiography.
Any assistance greatly appreciated.
Post #653616 15th Jan 2023 12:28pm
JayGee
Are these actually faults you can hear i.e spaekers and amp not working? If they are GAPIID fault codes then there are numerous false / spurious codes thrown with every fault check. 2012 TDV8 Vogue (L322)
Post #653617 15th Jan 2023 12:41pm
bearhouse
There be honest, they are fault codes. I've get to see if I can hear / identify the faults. But, the codes have come up twice when the garage have scanned for faults.
Post #653618 15th Jan 2023 12:44pm
Gaby13
United Kingdom 2010 Range Rover Autobiography Black 5.0 SC V8 Santorini Black
Hi, do you fix the problem?
I have the same faults code on mine
Post #698908 27th Aug 2024 11:14am
dingg1
2007 Range Rover Vogue SE 4.2 SC V8 Stornoway Grey
Everyone has these fault codes
As long as everything sounds ok
Fogetaboutit 👍
Post #698909 27th Aug 2024 11:17am
Gaby13
The sound doesn't work on mine
Post #698910 27th Aug 2024 11:19am
dingg1
Ah that's a different matter, but those cides have been standing on mine since I got it, everything works fine, so I don't think investigating those will help you...
Post #698915 27th Aug 2024 12:01pm
