Home > Technical (L322) > How to disable Superlock??
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Have a 2008 3.6 Vogue.
Have searched here and in the owners manual but can't find any clear guidance on how to disable Superlock. Anybody know? All the best
Chris
Post #698986 28th Aug 2024 8:05am
why would you want to?
from memory is it not one press for superlock and two for normal lock.. ... - .- -.
Post #698987 28th Aug 2024 8:26am
Paddy X350
I don't want to get locked out of the car if the battery drains. I have just solved (I hope!!) a battery drain problem, so just want to disable the feature until I am satisfied that the battery drain is fixed.
From reading the manual the double click on the remote disables the internal motion sensor, it doesn't mention the Superlocking being disabled.
Does the double click disable superlock on later models? Mine is a 2008. All the best
Chris
Post #698988 28th Aug 2024 8:36am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
I think that to enable the superlock you have to press the lock button twice so it should be disabled by default as long as you only press lock once after it's unlocked unless it's set in the CCM.
The one press superlock is enabled / disabled in the GAP IID tool, if single press superlock is enabled in the CCM then I'm afraid your stuck with it until you disable it back to default using the GAP tool.
On mine I had it enabled but disabled it because for some reason with the sunroof open on tilt in the heat the alarm went off all the time, but with it disabled it doesn't do that, but I can still superlock by the double press method with the roof closed when necessary.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #698991 28th Aug 2024 10:00am
Paddy X350
Thanks Andy,
Sat in the car and locked it with one press of the button and Superlock is enabled, couldn't open any of the doors from the inside. Double clicks on the remote did not disable it.
It's going into an Indy for some work in a week or so so I'll ask them to disable Superlock on one click of the remote for me. All the best
Chris
Post #699021 28th Aug 2024 6:40pm
