![]() | Home > Technical (L322) > fail safe program/ gearbox issue please help! |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
I would love to convert to a 6 speed...
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
I think the electrics/electronics would be the most challenging aspect of a conversion. You can buy an adaptor for the New Venture Gear transfer box (which is unique to the Range Rover) but I can’t help thinking that, overall, the cost of the conversion would easily exceed a replacement GM 5L40-E unit. Still be a very interesting project though.
I think you’re referring to the ZF 5HP24 transmission here, but the GM box does also have a reverse lockout valve. ![]() From the list of symptoms, though, I suspect courtec’s transmission has mechanical issues with the running gear and not just hydraulic/electronic ones, which unfortunately will necessitate a rebuild. Phil |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 52 ![]() ![]() ![]() |
The electronics should be possible, but Simon at ecux should be able to confirm. https://www.ecux.co.uk/?route=product%2Fca...eMVmSg32cg |
