Home > Technical (L322) > fail safe program/ gearbox issue please help!
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I would love to convert to a 6 speed...
Jim
Post #698926 27th Aug 2024 1:35pm
RRPhil
I think the electrics/electronics would be the most challenging aspect of a conversion. You can buy an adaptor for the New Venture Gear transfer box (which is unique to the Range Rover) but I can’t help thinking that, overall, the cost of the conversion would easily exceed a replacement GM 5L40-E unit. Still be a very interesting project though.
Phil
Post #698960 27th Aug 2024 6:54pm
RRPhil
pcourtney wrote:
....You may be lucky and just have an MV3 solenoid/reverse gear valve issue, so when you call around and one of them says it might be the MV3 - they might be the outfit to use, but the MV3 solenoids are usually very reliable - it does happen just that it's not common.
I think you’re referring to the ZF 5HP24 transmission here, but the GM box does also have a reverse lockout valve.
From the list of symptoms, though, I suspect courtec’s transmission has mechanical issues with the running gear and not just hydraulic/electronic ones, which unfortunately will necessitate a rebuild.
Phil
Post #699005 28th Aug 2024 3:30pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Phil
The electronics should be possible, but Simon at ecux should be able to confirm. https://www.ecux.co.uk/?route=product%2Fca...eMVmSg32cg
Post #699028 28th Aug 2024 9:15pm
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
courtec wrote:
Sorry to start this up again.
Garage have called today and told me the car now goes into all gears apart from reverse after it’s gearbox service. Gearbox hasn’t been reconditioned yet however he is saying he thinks my reverse has gone so will need the recondition. is this true? i don’t know what to think now Big Cry
Looking at the faults registered I would be sceptical about the gearbox needing a recondition at this stage. CAN bus failure and other electrical related errors indicate that there could be problems related to the wiring inside the box, solenoid faults, the gearbox ECU and cable loom between the box and ECU.
A gearbox service which I assume is a drain and new filter fixing some of the problems seems very odd to me. I would be wanting the electrical side to be fully checked out before committing to a gear box overhaul but I suspect this will involve a lot of labour/cost as well. Current: 2003 TD6 HSE. 161,000 miles
Previous 1993 Classic 3.9
Post #699043 29th Aug 2024 8:43am
