![]() | Home > Maintenance & Mods (L405) > Adblue Refill |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1462 ![]() ![]() |
Anyone found a foolproof way of topping up their adblue without getting it everywhere?
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1247 ![]() ![]() |
I only buy ad blu with a spout & I sometimes use a funnel which allows air to escape . Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
make sure you're sober when trying to fill it Rob..... |
you need something lie this mon ami,
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 73 ![]() ![]() ![]() |
Fed up of the gurgling, coughing and spitting back of the nasty stuff, I bought one of these. Laser also do one, slightly cheaper on Amazon. Works well for me:
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
I use a funnel slowly filling, by the way, GSF motor parts are selling 10 ltr for £13:44 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6761 ![]() ![]() ![]() |
£30 for a funnel? |
ash83 Member Since: 21 Jul 2024 Location: NYC Posts: 32 ![]() ![]() |
Funnel works fine. Just pour slowly |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
I’ve never found a way of not spilling some. However carefully I’ve poured, it seems to like gurgling back again as I suspect air is released.
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 366 ![]() ![]() ![]() |
I get the Costco one, it has a built-in funnel thing, and goes in quite painlessly. 2017 4.4 SDV8 Autobiography in black
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 108 ![]() ![]() ![]() |
Helps if the nose of the car is higher than the rear 2017 (67) Vogue SE Corinthian Grey |
spoils all the fun Stan ![]() ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Thanks for the replies all.
