Home > Technical (L322) > Ignition locked. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
could be simple - try this first
17th Aug 2024 4:33pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 420 |
I will try the above but from reading a bit more it sound like a ‘fuse 18’ issue. My steering column isn’t locked currently (key out car locked).
17th Aug 2024 5:15pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
I don't know if the fuse 18 trick is applicable to your MY but you can certainly try that. Alternatively you can disconnect the (-) wait for a couple minutes then reconnect and try the ignition again. If either of these tricks works and you still cannot hear the steering column locking mechanism in action upon offering up the key near the ignition barrel, then chances are that your column lock has failed in the open position (how they usually fail). An emulator, imho, is your best option as it is less than 100 quid to buy and less than 15 minutes to install by yourself. You do lose the steering column locking functionality but with the way it is designed, I don't really want it on my car and besides, any self respecting car thief couldn't care less. |
18th Aug 2024 10:37am |
Is there a respected emulator company / brand? From what I have read there’s a bit of wiring work do do? Or is it just plug and play?
18th Aug 2024 11:11am |
If you prefer to get it done by experts, there is a firm that I used in Brentwood ( behind the car wash place ) , and if you can't drive it there, they will come to you.
18th Aug 2024 11:16am |
Great thanks, what issue did you get solved? The same thing?
18th Aug 2024 11:35am |
They sorted out a few things when I bought my 2004 L322 car, as you know there are lots of BMW parts used on this era of cars, plus the M62 V8 engine, the guy that came out was excellent, knew about the EWS ( another BMW part) and sorted out the ignition not turning, the steering lock, and cut 2 more keys and coded them for me ( I had already bought the blank keys with transponders in them )
18th Aug 2024 12:15pm |
If you are willing to have the steering column lock repaired and can get it done for reasonable money, then by all means go ahead. That is what I did. But the lock failed again withing weeks of the repair. The garage did make right but I had also ordered my emulator from Goldcar. It is a Turkish company so expect some inport dues + vat, about 100 quid all told. Delivery was by DHL within 5 working days. Last time I checked they had updated their plug connector with a latch safe. And it's 100% plug and play; no wiring no soldering; just unplug the ECU and plug the emulator. I made the conscious decision to use the emulator instead of my repaired lock and it's been working flawlessly for almost 3 years now
18th Aug 2024 12:28pm |
Thanks for all the advice so far. 2009 pre-facelift 3.6 TDV8. |
18th Aug 2024 7:36pm |
I’m not far from Brentwood. Wonder if they use the same Turkish emulators. 2009 pre-facelift 3.6 TDV8. |
18th Aug 2024 8:57pm |
Kit - what did Car Solutions say ?? |
19th Aug 2024 2:29pm |
I got through to some bookings agent, I think I need to find the number for the actual Brentwood site and give them a call.
19th Aug 2024 2:49pm |
this might be the Brentwood Branch 020 8088 3140
19th Aug 2024 3:13pm |
Thanks.
19th Aug 2024 7:30pm |
