Home > Technical (L322) > Ignition locked. |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
I think what you're describing is a feature that enables easier entry/exit. IIRC is within the car's configuration and can be disabled if you so wish. I have it disabled with the column fully retracted and at the uppermost position and give the column motors a workout myself every once in a while instead... |
19th Aug 2024 7:38pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 420 |
Does anyone have any knowledge about a message on the dash that reads:
19th Aug 2024 9:47pm |
Hi,
20th Aug 2024 6:49am |
It started fine after a battery charge.
20th Aug 2024 9:04am |
The working of the column locking arrangement is quite loud, loosely resembling a gun action. If the battery is old or has seen better days, you're better off replacing it anyway to eliminate guesswork in this regard
20th Aug 2024 9:24am |
Never had an issue with it and I believe it’s an oem Excide version. Will check the previous owners paper work (extensive main dealer history in my case) to see when it was last changed.
20th Aug 2024 9:31am |
