Home > Technical (L405) > Resetting windows one touch function
PhillV8s
United Kingdom 2013 Range Rover Vogue SE SDV8 Aintree Green
My FF has been parked up for a few months due to a broken leg and the battery is kaput. Tried charging with my trusty CTEK but even that failed to bring life back to battery. I decided to treat my self to a NOCO boost pack and this did manage to get the car started thankfully but the battery is going to be replaced as it’s had it. Whilst I had the engine running i quickly checked obvious issues and found the one touch function on all 4 windows only worked on the down not the up. Tried holding the switch down for longer when fully down then fully up but no joy. Is there a proper reset procedure for these? 2013 SDV8 4.4 Vogue SE Aintree
Post #698252 17th Aug 2024 4:11pm
Waylander11
Not sure if it’s the same but on my discovery 4 it’s all the way down all the way back up let go then hold the button in the up position for a few seconds
Post #698269 17th Aug 2024 9:14pm
PhillV8s
Tried that already, no joy. 2013 SDV8 4.4 Vogue SE Aintree
Post #698270 17th Aug 2024 9:22pm
When I replaced the batteries in mine & needed to reset, the rears worked first time but the fronts required a bit off playing around.
The manual states - "Reset electric window one-touch facility. Power window up to hard stop, release switch, reapply and hold for 1 second (relay in door will click). One touch should now work"
However, I tried a few things, locking & unlocking, ignition on & off - not sure what it was in the end, but suddenly the fronts worked too.
If it's OK on down but not up, that sounds more like a CCF setting, but hard to see how that would have changed......
Post #698279 18th Aug 2024 9:12am
PhillV8s
Thanks, I’ll have more of a play with it I think, I can plug in the IID tool to see if any seems amiss there also. 2013 SDV8 4.4 Vogue SE Aintree
Post #698284 18th Aug 2024 10:04am
I just checked mine - on the main dash menu, there's a Vehicle Setup option and if you scroll down, you can select Open & Close independently -
Post #698287 18th Aug 2024 10:37am
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
just checked mine. Also boxes checked in main menu, but passenger side same problem: one-touch down works fine. No way to prgram the one touch up function Question Evil or Very Mad 2013 L405 3.0 TdV6 Autobiography Barolo Black
2004 L322 3.0 Td6 Vogue Cairns Blue (gone)
2000 P38 2.5 DSE (gone)
Post #698292 18th Aug 2024 11:39am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
It's general rule on Land Rovers about the wind down, wind up, then hold the up button till you hear the door click.
However, I did read somewhere that one touch up and global close doesn't work in all markets.
I've noticed that mine "unlearns" this, whenever I do a GAP change or sometimes randomly, so I have to reprogramme them occasionally, but the process is the same.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #698350 18th Aug 2024 9:56pm
PhillV8s
Fitted a new battery today and followed reset procedure as posted and hey presto, success. Found releasing the window switch for a second was the part of the sequence I had missed before. Thanks all. 2013 SDV8 4.4 Vogue SE Aintree
Post #698379 19th Aug 2024 12:36pm
