Home > Technical (L405) > Resetting windows one touch function |
Waylander11 Member Since: 06 Nov 2019 Location: Leicestershire Posts: 19 |
Not sure if it’s the same but on my discovery 4 it’s all the way down all the way back up let go then hold the button in the up position for a few seconds |
17th Aug 2024 9:14pm |
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 31 |
Tried that already, no joy. 2013 SDV8 4.4 Vogue SE Aintree |
17th Aug 2024 9:22pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7911 |
When I replaced the batteries in mine & needed to reset, the rears worked first time but the fronts required a bit off playing around.
18th Aug 2024 9:12am |
Thanks, I’ll have more of a play with it I think, I can plug in the IID tool to see if any seems amiss there also. 2013 SDV8 4.4 Vogue SE Aintree |
18th Aug 2024 10:04am |
I just checked mine - on the main dash menu, there's a Vehicle Setup option and if you scroll down, you can select Open & Close independently -
18th Aug 2024 10:37am |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 162 |
just checked mine. Also boxes checked in main menu, but passenger side same problem: one-touch down works fine. No way to prgram the one touch up function 2013 L405 3.0 TdV6 Autobiography Barolo Black
18th Aug 2024 11:39am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 528 |
It's general rule on Land Rovers about the wind down, wind up, then hold the up button till you hear the door click.
18th Aug 2024 9:56pm |
Fitted a new battery today and followed reset procedure as posted and hey presto, success. Found releasing the window switch for a second was the part of the sequence I had missed before. Thanks all. 2013 SDV8 4.4 Vogue SE Aintree |
19th Aug 2024 12:36pm |
