Home > General (L405) > Suspension - Access height to get into garage
StraightHalfMile
Hi all - looking to dive back into LR ownership with a 405 (probably 2018 SE or thereabouts).
My last LR was a 1980 Series 3, so I'm hoping there'll be less water coming in the top, and less oil coming out the bottom...
I have electric roller shutters on my garage which open to around 1825-1830mm - am I right in thinking that you can use the "Access Height" mode to manouvre in and out of parking?
Online manual suggest standard height is 1867mm with antenna and claims 50mm lower when in access height (so 1817mm).
Thanks!
Post #698181 16th Aug 2024 9:54am
dhallworth
Have you got a perfectly level driveway into your garage?
If you do then you might just be able to get away with it, however, if the back of the car is slightly higher then the front of the car as you go in to the garage then the 8-20mm clearance you have will not be enough.
Personally, with only 8-20mm of clearance, I'd be of the opinion that the car won't fit in the garage as that's not enough clearance for comfort.
In theory, with an IID tool you could deflate the suspension to get it to sit even lower but that becomes a lot of hassle and regular storage of the car with the bags creased and no pressure in them probably isn't a good idea. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #698190 16th Aug 2024 12:39pm
caymanblack
Yes you can drive into the garage in access mode you can also lock it into this mode. overfinch modified
Post #698202 16th Aug 2024 4:16pm
comports
I’m also used to do this my works and underground Carpark as it was tight…
You MUST remember to do it however if it’s that close.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #698210 16th Aug 2024 6:25pm
StraightHalfMile
Thanks all!
Post #698229 17th Aug 2024 9:18am
GraemeS
Australia
It's not a permanent lock, it only allows a faster speed before raising.
Post #698230 17th Aug 2024 9:24am
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
If you decide to do this I’d suggest a tennis ball on a piece of string suspended above the door to remind you. It would be a disaster to forget! 2017 (67) Vogue SE Corinthian Grey
Post #698246 17th Aug 2024 2:26pm
caymanblack
True Graeme, I think its about 25/30 mph. overfinch modified
Post #698248 17th Aug 2024 3:28pm
GraemeS
Australia
I just checked my L322 owners hand-book and was surprised to see that crawl mode is cancelled above 24 mph. I had in mind that it was much slower.
Post #698271 17th Aug 2024 9:42pm
