Home > Technical (L322) > Remove Wiper Washer Mechanism from Headlight Assembly |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 819 |
There is a grey rectangular piece of plastic which holds the wiper arm, and getting to it and removing the arms looks to be a devil a job, so I think probably best left for now
13th Aug 2024 2:07pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
The cover / cap can be lifted from its oval end (1). It hinges against the arm (dashed line) by about 30 degrees on its two lateral tabs before it can be pulled out (2). This will reveal the securing nut. Undo the nut and wiggle the arm off the shaft.
13th Aug 2024 6:11pm |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 104 |
Copied from the world wide web: All vehicles registered since 1 April 2000 that have a dipped beam with a luminous intensity of more than 2,000 lumens must have a headlamp cleaning system.
14th Aug 2024 3:49pm |
