Home > Technical (L322) > Is this battery correct?
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I have a battery monitor connected to my TDV8 4.4 2011 and it shows battery and Charging as good but the cranking voltage is low. I normally use it daily but I left it for a week and it only just started.
Is this battery correct? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #697838 11th Aug 2024 5:04pm
Buellie
Post #697839 11th Aug 2024 5:07pm
Buellie
Post #697840 11th Aug 2024 5:07pm
Just type 013 into Search Whistle
Seems like it's too small & you'd be better with an 019 or 020
Post #697841 11th Aug 2024 5:39pm
Buellie
I think the 13 and 19 are the same from googling Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #697844 11th Aug 2024 6:08pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I have the same battery monitor and used it on my last FullFat (it’s now fitted to the F Pace).
The cranking result can be low if you have done a number of short journeys or if the car has been standing unused for a while. Go for a good countryside or motorway run, say thirty minutes at least then stop and restart and check the cranking voltage. It usually then goes into the green but I don’t take much notice of the reading to be honest.
(I’d be tempted to look at replacing it with an 019 personally). 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #697847 11th Aug 2024 6:53pm
Buellie
Thanks Chris
If you look at the Tanya website it seem the 019 and 013 are the same battery (non-agm) maybe the cranking power is different
Link
https://www.tayna.co.uk/car-batteries/bosch/s3013/ Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #697849 11th Aug 2024 7:17pm
Buellie
Just looked again the cranking power is lower
I think I'm going to get this one with a 5 year guarantee, thoughts?
https://www.tayna.co.uk/car-batteries/varta/a5/ Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #697851 11th Aug 2024 7:39pm
chris_read
Presumably that was one of the recommended ones for your reg number. I had the 3.6 TDV8 so I went for the H3 Varta, which is currently £112 plus delivery. Perhaps the 4.4 needs a different (and more expensive) battery Question 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #697854 11th Aug 2024 8:01pm
pcourtney
yes the last 2010 models onwards TDV8 4.4 are better served with 019 AGM battery, even though it is not a "Stop Start" car, the BMS is able to charge it better when they have AGM batts in them - they cost more though approx £160
Post #697855 11th Aug 2024 8:22pm
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Buellie,
Try the Battery Group based in Barnsley, South Yorks as they they are very good price wise.
https://batterygroup.co.uk/batteries-by-ty...gIicvD_BwE -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #697874 12th Aug 2024 11:55am
Buellie
Griffey thanks for that info Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #697876 12th Aug 2024 12:23pm
